Hi
under respect of the Datasheet, testing should be done
How do you do this?
what else would work?
thanks T
4. Test conditions
4.1 Test environment conditions Temperature:25±2℃ Relative humidity (RH): 15%~85% Atmospheric condition:86KPa~106KPa
4.2 Standard Charge The standard charge means charging the cell with charge current 0.5C(A) and constant voltage 3.65V at (25±2)℃, 0.05C cutoff.
4.3 Standard Discharge The standard discharge means discharging the cell with discharge current 0.5C(A)and cutoff voltage 2.5V at (25±2) ℃.
How do you do this?
thanks T
