testing internal resistance
hwse
Any tutorials on how to test internal resistance? What tools and / or meters are required?
Did you happen to see this page?
I've seen a lot of internal resistance testers before on Amazon:
I've never used one myself yet, and haven't really found the need yet to bother checking any of my cells, as mine all seem to work fine out of the box. I guess some may want to test their for learning or troubleshooting / optimization purposes, which is perfectly fine to do.
It seems like I thought Will Prowse had made some You Tube videos on testing internal resistance, I think I remember seeing some before.
Here's a random search on You Tube (that Off grid Garage guy knows a bunch of stuff):
More background info:
I had seen that $26 tester and it is partly what prompted my question. I posted a question on Amazon about the minimum milliOhm reading and someone said 1.0 milliohm on the 3.2v LFP setting. That is fine for small cylindrical cells but as the capacity goes up, the IR goes down so on our 289A cells, it is down around 0.18-mOhm so it would not be able to read it.
Andy at Off Grid Garage uses one that will read down to 0.01mOhms which would be fantastic but it is only available on AliExpress and it would take several months to get to me.
I did some more searching and found this unit that looks to have 0.01mOhm resolution that should do the 280A cells.
Yeah, you could check the return policy and if it proves not to work out for you, you could return it.
