In the corner of my Texas garage I have two 200 amp breaker panels and I am thinking of putting on the wall next to them a Sol-Ark 12K, 2 critical loads panels, gutters, & related components (cutoff switches, etc) and on the ground under the Sol-Ark a 6 rack for EG4 batteries (solar panels will be on my south facing roofs).
This is the 2nd winter in a row where temperatures are in the teens (and I think last year we were in the single digits) and in the summers it regularly breaks 100 degrees and the garage gets really cold and hot...
With the above in mind I am thinking it may be wise to enclose the corner of my garage and install an combined air conditioner / heat pump to condition the enclosure which I envision would end up being something like this (& heavily insulated):
Currently the wall that has my main breaker panels and wall next to it are both brick on the outside and sheetrock on the inside though I don't really know if those 2 walls are well insulated.
In wall preparation before putting in the equipment I had the following questions:
Q1): Should we put up cement backerboard (CBB) on the wall where the equipment will go?
Q2): If cement backerboard (CBB) is recommended, is HardiBacker with HydroDefense the best for this use case of is some other brand recommended?
Q3): If CBB is recommended, would it be advisable to put something that accepts screws better than CBB (like plywood) on the wall first before putting in the CBB?
Q4): If putting up CBB is recommended, should I remove the sheetrock first or just put the CBB (& maybe plywood) over the sheetrock?
Q5: Considering I likely will come back and enclose and condition (cool/heat) the space, would it make sense to put something like Reflectix over the CBB and if yes what R-value would be recommended?
Note that if I do end up enclosing and conditioning the space I may also move one or more servers from our home offices into there.
