Photosolo
- Dec 22, 2019
- 26
Not sure if this is the right place for this post… I’ve finally got around to starting my battery build.
5mm minicell foam between cells
Plywood case with some threaded bar & wing nuts for compression.
I’ve no idea on the right amount of compression, my thoughts is a little compression is better than none?
One unforeseen issue that arose was my stock busbars no longer fit due to adding 5mm distance between studs. So I’ve taken it as an opportunity to order some flat copper bar & will create some fresh busbars ASAP.
It’s all starting to get real !
