Yes, 10000TLUS said "IGBT error", not sure what state it had been in.
5000US, when it checked line voltage before reconnecting, said something like relay error. Turning off VFD didn't fix, but power cycling PV input did. I think it fed OK with VFD on, but had the problem connecting.
Maybe yet another inductor on input of VFD would help? Slight improvement in PF and waveform but not ideal.
What we want is a front-end that follows AC voltage sine wave and synthesizes sine wave current to charge the capacitors. That does exist, but don't know of an add-on unit.
Well.....
Here's an update.
I used
https://ebay.us/cHQj6Y
Short answer , so far so good. Long answer below.
This is all being set up and tested in my shop before taking it out into the desert.
Solar setup:
2 x Sma si 6048 for 220 split ph
1 Sma Sb 7.7
1 Sma tu6000us
2 16s 280ah lifepo4 batts parallel to 1.25x.375 buss bar.
Batt to bus 2/0 copper welding wire
Buss to Si6048 3/0
Rec bms 1 master 6 slaves
1 array trina 250w 12 in series
1 array trina 250w 6 in series
Now I want to test this all out and see if I can run the 3hp well pump. Pump will be at 1030 feet. Bottom 100 feet is number 4 copper well wire. That's 40 submerged and 60 feet above the water level. The balance is 900 feet of number 2 aluminum direct burial wet environment wire.
For a test so far.......
Hooked up the vfd to the Power produce by the inverters. Set ramp for 50 to 60hz over 4 sec. Fired it up , all good no issues.
Ran 50 foot of #10 extension cord up to machine shop and wired it into the 3ph supply. Turned of vfd and then tried a massive 5hp surface grinder. Nope to much surge. It has a mag starter so it's not used in the rest of testing.
Reset vfd. Turned on 3hp turret lathe , the initiated vfd. Ramps up perfect. No faults on inverters.
Turned everything off. Though , go for broke. Turned on 3hp lathe , 1.1hp mini mill , and last but not least , the 2hp Bridgeport mill.
Hit the vfd and crossed my fingers . All ramped up , no faults , and only had amp clamp on one leg. 48amps max inrush.
So far so good. I used the 50 foot cord forb2 reasoned. I had it , and thinking with a bunch of line loss , maybe it would stall.
Next test will be same setup , except through the 100 feet of copper and 1000 feet of aluminum.
If will be a few days to do it , but I have Hope's. Then we will see if I need the reactor.
Greg
