Looks good with a quick review. Will you have a Class-T fuse between your load shunt and main disconnect? You may want to give yourself more space in your positive busbar, you're likely to add more draws over time. Also I'd suggest upping your Battery Protect to the 100A one, it's not much more money and it's nice to have some extra headroom.
You'll need to check if your inverter has an internal bond to chassis ground:
https://diysolarforum.com/resources/grounding-details-for-specific-make-model-of-inverters.156/ and wire appropriately. I'd also say that 1/0 wire for your chassis ground is overkill, 6ga should be plenty.
Overall, nice job. You've done your homework!
