I wasn't sure where to post this so general discussion it is.
I posted in another thread on the subject of unfavorable changes to net metering with my provider. A coop that I have no option to escape from.
I am grandfathered until Feb 2028 on the current 1 to 1 net metering per billing cycle so I have just under 5 years to come up with a solution, assuming it is even a problem. I believe it is. See the link above to the post where I went into detail.
I am thinking that taking my solar system off the grid t0 avoid the $15 distributed generation fee and pultry buy back by my provided and only purchasing electricity from them when needed because solar & battery is not enough, is the way forward to making things more cost better for me. I was not really a candidate for solor from an ROI perspective, but that was not my sole reason for going solar.
1) I have very young grand children I want to do my part to leave a better world to.
2) I have been doing the opposite of number 1 for my almost 60 years on this planet
I do have at present a small grid interactive battery back up system and believe expanding on this would be the way forward. I am always open to suggestions, questions, and thoughts (constructive only please). With inverter tech changing as rapidly as it is these days, perhaps my solution does not exist quite yet.
My current system & basic data. My 1600 sq/ft house is completely electric.
28 x REC 370w Alpha Black Panels with
28 x Tigo TS4-A-O optimizers, grid tied to
1 x SMA Sunny Boy SB7.7-1SP-US-4.
The separate grid interactive system is.
6 x EG4-LL 48v 100AH batteries hooked up to
1 x MPP Solar LVX6048 connected to
1 x Eaton CH10gen5050sn switched neutral critical loads panel.
Batteries are charged via AC in only. No PV hooked up yet as my roof is full and I don't want to void my warranty by pulling one string off the Sunny Boy to feed the LVX6048. This separate system is my setup to experiment with battery backup and learn for the day that net metering changes unfavorably. That day arrives in 5 years.
My absolute peak electricity usage was 18kw at a time when all high draw loads were running concurrently along with regular loads: Dryer, Oven, Emergency Heat (resistive coils 10kw). I have a heat pump which draws around 2kw heating or cooling. I might use emergency heat once or twice a years (Dallas Texas).
My base load is between 850 to 1000 watts.
Here is some monthly usage data from 11-2021 through 04-2023:
Any insights, suggestion, questions are greatly appreciated.
Thanks in advance.
Consumption | Generation | Net |
516 | 609 | -93 |
625 | 623 | 2 |
769 | 735 | 34 |
731 | 838 | -107 |
689 | 795 | -106 |
606 | 1068 | -462 |
609 | 857 | -248 |
613 | 860 | -247 |
488 | 522 | -34 |
553 | 446 | 107 |
600 | 614 | -14 |
690 | 760 | -70 |
734 | 549 | 185 |
686 | 495 | 191 |
846 | 777 | 69 |
899 | 590 | 309 |
545 | 735 | -190 |
595 | 833 | -238 |
Thanks in advance.
