I'm working on a project that requires an inverter with a particular set of characteristics. So far, the hunt has not been terribly fruitful. Can you help?
The Cotek SD3500-148 is the closest I've found to meeting the need. A sound candidate, if a bit shy on power and not rack mount.
I'd love any other ideas on make/models. Thank you.
- 3500-4500 watts
- 48 VDC input / 120 VAC 60 Hz output pure sine wave
- Parallelable! This is important
- Off-grid use only (does not require AC transfer switch etc)
- Does not need to have mega surge capacity and needs to be reasonably lightweight (high frequency)
- Ideally rack mount. A panel mount unit is workable Plan B though.
- Integrated battery charger is welcome but not mandatory
- Portable, so a degree of "shock & vibe" tolerance that's between a telecom inverter and a full-on mil-spec unit
