FilterGuy
Solar Engineering Consultant - EG4 and Consumers
That seems unlikely, but you could check by disconnecting the pumpI'm also wondering if the 18 farad capacitor could be the problem.
But do one thing at a time. Find the problem - then you know what it is/was and it won’t show up again.thinking about rewiring the inverter output as well, and just bypass/remove the transfer switch all together.
Time to look for another BMS...
Daly 16s 200a modelWhat kind do you have now? The one that died I mean.
Daly 16s 200a model
I agree. Ill see if I can get this BMS warranted and maybe keep it as a back up. I'd like a BMS capable of handling 300a, that way it's more than capable of supplying the 2x LV6548s.
Starting research now. I'd also like one with higher amp active balancing... hmmm
Not yet, they are still waiting on Seplos to update software, whenever that will be. Only downside to the Seplos is they only go up to 200a.MPP LV6548
Just got two of these this week and im waiting on my last set of 280ah cells to arrive. Can’t WAIT to turn them on. Will, do you have any setup videos on this inverter? @DanF @Will Prowse Question if you guys get time: My biggest issue is I can’t figure out what BMS I can use that will...diysolarforum.com
Did anyone confirm the Seplos BMS works with the LV6548 in Pylontech mode?
With a properly sized contactor it wouldn't matter.Not yet, they are still waiting on Seplos to update software, whenever that will be. Only downside to the Seplos is they only go up to 200a.
I'm looking into the Orion BMS right now, gotta do a lot of research though...
1) I unhooked both the inverter input and output. As well as disconnected the 50a umbilical cord from the grid to ensure no power to or from anything. I left the solar PV Disconnects on, and turned on the inverters. They both came on, and I currently have 30VAC from earth to trailer. I'm guessing its lower than usual because it is extremely overcast right now and I have almost no solar coming in. When I turn the inverters off, I get less than 40mVAC. When I shutoff the PV Disconnect to the shipping container array, I get less than 40mVAC.OK.... If I am following along correctly this is the current set-up and the problem persists.
There is not much left to unhook, but let's keep at it.
Next steps
1) Unhook the inverter outputs. (Note: The inverters might say there is a fault after you disconnect the output. If so, content the two neutrals together and try again.)
- Does the problem persist?
2) Disconectt the DC-DC converter
Wow, there is not much left to disconnect.... and yet there is still a problem. The only other thing I can think of is to test with only one inverter at a time.I'm leaning more and more towards the wires that are going to the container. Maybe they are faulty from the manufacture and leaking current into the ground? Or there is just damage somewhere I didnt see. The fluctuating VAC from earth to trailer leans me towards the PV wires more too, I feel it would be more steady if it was actually coming from the AC Output/Input of the grid and/or inverters?
I did replace the main board in Inverter #1 myself. Could I have messed something up?Wow, there is not much left to disconnect.... and yet there is still a problem. The only other thing I can think of is to test with only one inverter at a time.
This one really has me scratching my head!!!
4 wires total. 2x Positive PV wires and 2x Negative PV wires. There are 2x 6s2p arrays on the container. No ground wires.Only PV + and - going to the container, no other wires (including no ground)?
I think I asked you to measure AC voltage of those two PV wires relative to RV chassis, and you said zero.
If they did have AC voltage, that would capacitively couple to container which grounds to earth.
I wonder if I try and drive a grounding rod next to the container and ground the container itself.
What size should the ground wire be? I haven't heard or seen of anybody grounding their solar panels before, but then again, I am still the noob here lol.Run a ground wire from RV to the container. That way, if PV panels induce a DC or AC voltage in the container (and the Earth), the RV won't be driven to a voltage relative to Earth. That is proper grounding to protect against cracked/leaking panel anyway.
But first, measure voltage from RV chassis to each of those PV positive and negative wires (again) under conditions where you do measure AC voltage between RV chassis and Earth.
Ok, I'll order a 500ft spool of 18ga or something to run along with the PV Wires. Do you think the panels on the roof of the trailer should be grounded as well? I'll have to drill a hole in my roof...The proper wire gauge would have sufficient ampacity to carry the current PV strings can produce.
To solve this low-current shock, if it is related to capacitive coupling, any size wire at all would work, even phone wire.
Section "The Array" 2nd paragraph describes frames bonded together and a wire run with the circuit conductors.
What is the process of grounding and bonding a solar PV array?
The National Electrical Code (NEC) requires bonding electrically conductive materials and equipment to establish an effective ground-fault current path.www.solarpowerworldonline.com
"Equipment Grounding" page 9
Often, negative PV is referenced to earth ground at the battery. If a wire rubbed through its insulation or a panel cracked (or otherwise developed leakage), PV frame could be hundreds of volts DC, whatever Vmp or Voc is. It could present a lethal shock hazard.
If you have MC connectors, could use a Y cable. If a junction box, access its screw terminals or bring out a pigtail wire (preferably ending in a shrouded conductor so no exposed hot leads.)
