Finally received my BMSs. They were supposed to have fans but somehow must have got lost in translation... I have a message out to my seller, but its already been 24 hrs...
Finished my dads battery for his motorhome. He just wanted a 12v 272AH, to replace his 4x 6v Trojans that are now 8 years old and tired. 150a Daly BMS with Bluetooth and low temp cutoff. I can also confirm the low temp cutoff works like a charm, and is very quick.
And now my battery... I bought a 200amp model, also with Bluetooth and low temp cutoff, which confirmed works as well. I also bought the light board and the touchscreen display off of ebay, and I gotta say, im impressed! The light board was $10, and the display was $35(?) I think. I used the lightboard to turn it on, which was super easy, then I hooked up the display and was able to set LVD and HVD as well as high and low temp cutoffs. Very easy. I set low temp cutoff to 10C and put it in the alcoholic beverage i happened to have and it shut off very quickly.
Only problem i have seen is for some reason the battery type keeps changing itself back and forth to Titenate on its own. Im gonna connect to Bluetooth and see if its just a phantom problem though.
