The Most Basic of Parts Questions
Texan74
Texas
Have a few (hopefully basic) questions about parts for a system. I was a light-duty diesel mechanic by trade, and now part-time as a rancher while full-timing as a curmudgeon đź‘´
I'm looking at the wiring diagrams for the EG4 18kPV because on Page 36 of that manual these is a large wiring diagram of a parallel inverter set up. Would anyone here please be able to provide me links to a purchasable product for these boxes on the diagram:
PV Interactive System 2-Pole Disconnect 200A
Dedicated Grid Input Combiner Paner (200A)
Dedicated Inverter Output Combiner Panel (200A)
2-Pole Manual Transfer Switch 200 Amps
Fused Positive Battery Bus Bar >= 500A (Class T fuses - 200A @ 58 VDC)
Negative Battery Bus Bar or Power Distribution Block >= 500A
200A Feeder Tap Breaker (NOT the feeder taps themselves)
I've believe I've correctly located many of the items on my own, but want to compare what I found to what others might know about to confirm that I'm on the right track.
You might get a better response if you post links and ask if these will work or if there is a better option.
Otherwise asking someone to complete your internet shopping list might not get a lot of takers.
@Texan74 , I'd try this place called The A-ma-zon.
Wow, you're so very helpful. The entire point was to ask for independent verification because these items are expensive.
But really, your insights are just so overwhelming helpful that I've lost 5 pounds, changed religions, and created a non-profit for the benefit of people who can't read good. Thank the Lord there's an "ignore" button here.
It's not an "internet shopping list". You can feel free to link to manufacturers that don't offer direct sales if it makes you feel better.
If I put up items that I've found then I'm biasing the responses. The point of the request is since that the inverter manufacturer is intentionally vague regarding products they don't offer, I'm trying to see what other people consider to be appropriate items that fit the specifications.
As I stated I have found these items. Seeing as how I'm not going to get any help here because I won't answer my own questions, I'll be leaving now. Thought that this would be a helpful place, guess it's very different from other boards that I'm on where people share knowledge. Given the incredibly sarcastic response I received after your, I have no faith in this place any longer.
Yeah I know what you mean. I've just done a ton of searching on here for specific models I'm looking at; that and the Signature Solar page. I've wound up buying things from Alibaba, AliExpress, Amazon, and Signature. The only things I've purchased that are on your list are
and a TOMZN brand 250A DC breaker that I can no longer find anywhere.
I've not installed any of them yet so I have no feedback to provide.
