Hi,
i'm new to the forum. I'm trying to figure out how to connect 5x 410W panels.
I have 2x EPEver tracer 4210AN. It is MPPT and can handle 40A, 100V, max input is 1040W/24V(battery voltage system)
Panel speicification:
Max voltage Vmp: 38,80 V
Max Current Imp: 10,57 A
open circuit voltage Voc: 46,60 V
short circuit current Isc: 11,07 A
all panels are placed on the same west site 3 vertically 2 horizontally (should not matter?).
What is the best option for connection? 2 x 2 (parallel / seriell) to the first tracer and the last one alone to the tracer 2? It is better to connect the modules parallel (each two) and then this 2 strings seriell or first seriell and then parallel?
shall I take longer cables (max 6 meter distance) for each solar module and make the parallel / sequentiell connection in one place?
I hope, you could share your expirience, knowledge with me...
- positive: I have access to all module strings separatelly, can disconnect, test, reconfigure the modules.
- negative: need more cables/costs.
- Not sure: Is there any negative impact to the performance of the MPPT Tracer if the length of the cable differ by 1-2 meter?
- positive: less costs/cables
- negative: for reconfiguration I need to dissamble modules, I cannot test the modules separatelly.
