Thermal cam, best purchase I've ever made....
You folks have got me all worked looking at this again. LOL Is this the same one for cheaper than Amazon?
Its the same one ($479.00) - but: "Temporarily out of stock - back in stock in 2 to 3 weeks". ?
Black friday/Cyber Monday will then be over...
On Amazon its $439.20 (Prime Exclusive Deal) at the moment for US.
That cheaper one on Amazon is the lower resolution "Pocket 1"
TruTech let me put "Pocket 2" in my cart and I assume will let me check out.
I have wanted a thermal camera for a while, glad to see the tip about Amazon!
Ordered one of these, supposed to be here Friday:
$150 off in Canada for black Friday.. Cheaper than the HIKMICRO Pocket 1…. Arriving on Dec 7th! ?
up until now, the seek thermal camera is what i’ve used to do thermal imaging. it has been… okay… and requires a phone to use. and is kind of buggy, low res, and slow refresh rate.
ordered the pocket2 as a hopeful standalone replacement. will share example pictures when it arrives.
excited to have a more powerful standalone device to diagnose and inspect my installs.
thanks for the tip folks.
WoW!
I just love it…. Just received it, a week before estimated delivery. Very simple to use, the image is clear, connection with my iPhone completed in 20 seconds. Temperature reading seems to be good (I will confirm next time I go to my chalet), I can easily see warm spots on everything so any issue with my wiring will be obvious for sure…. Really exactly what I was looking for and for less $$ than expected. Very happy…
(Now I have to find out how to capture an image without the onscreen information ?)
Here is an example that made me confirm that an Apple TV consumes power even when turned off…. Impossible to feel the difference with my hand. If I remove the device from my speaker, I see the warm spot even if there are only a few degrees between it and the rest of the surface…. (Sorry if the image seems off, the camera was set to 5 ft).
I use a Pulsar XP38 Thermion scope. It will detect a mouse at over 100 yards, and a person at almost a mile.
I can even see the temperature difference left behind a duck swimming in a pond, or the heat signatures left by someone pushing keys on a keyboard. (by the way, they can use these at ATM machines to figure out your pin code so always put your warm palm over the keypad for a few seconds when you're done)
Last year, I was trying to put a nail into a stud and my stud finder wouldn't work because the kitchen wall was an "outside wall" with insulation behind it. Pulled out the Thermion scope and I could easily see the studs by the temperature difference.
Of course, a Thermion XP is far more expensive than one of these phone gadgets, but thermal scopes are amazing.
WoW!
I checked today and mine hasn't even shipped yet. :cry:
You can switch off the temperature display in the device (max, min, cen) and the associated crosses. But what remains are the lower data and the temp scale.
If you download the "Hikmicro Analyzer" PC software from their website (www.hikmicrotech.com) you can import the photo there: Only the pure thermal data is then available without on-screen data. You can then also change the palette or the level span in there afterwards.
Also make sure your firmware is up to date: Hikmicro recently made some changes that improved the thermal resolution in a narrow span and the sharpness of the image to be able to resolve finer details better. No major effects but helpful in certain borderline situations.
The Thermion XP38 has the same NetD as the Hikmicro devices as the lens aperture on the Thermion is only f1.2, reducing the stated NetD (which is always measured at f1.0). Both devices should be about equally sensitive. You just see further because of the high magnification and a higher resolution. The Pocket 2 has a wide-angle lens.
Looks like the 2-3 weeks came true... ?
Hikmicro makes thermoscopes, handheld devices, android devices, monoculars, and all kinds of stuff.
Thermal imaging quality is mostly centered around the size of the germanium glass, the microbolometer (that's the sensor), and its sensitivity. The germanium glass up front is the biggest variable as it is said to represent over 40% of the cost of most thermal devices. Apparently, germanium glass is stupidly expensive. As for the bolometers inside, only a few companies in the world make them so regardless of the brand name, its going to have just one of a few names inside.
Beyond that, the rest is application design. Most thermal devices can't take the shock delivered from a 12ga shotgun. Drop them or bump them hard enough and many are likely to stop working. Try to use them in the rain, they stop working, try to use them in extreme temperatures, they stop working.
You really do get what you pay for. If you want sensitivity, you're not going to get any range. If you want range, you're not going to get anything that's very sensitive. And if you want both, then be prepared to do what I did and open your wallet. There's a big difference between a $400 device and a $4500 device.
The area of application of the device for a shot gun is completely different from checking solar panels for functionality. ;)
The sensitivity is almost the same between top-outdoor devices and hikmicros measurement devices. The difference lies in the software since no accurate temperature measurement is neccessary in the outdoor devices: You can use sharpness filters exaggeratedly and AI support for visible identification.
With my posting I just wanted to refute your statement that your Thermion XP is more sensitive than for example the Pocket 2. That's not the case. With a Pocket 2 you can also see "heat signatures left by someone pushing keys on a keyboard". But both devices have their right to exist for very different applications. And they are not "gadgets". Of course your Thermion XP has a higher price because it has a bigger lens and sensor resolution and obviously a lot was invested in the software to make such a flawless optical view possible.
I'm glad you posted this.
I had no idea thermal scopes could focus down to distance practical for electrical inspection.
However, they do!
The zoom is a little annoying, and there is no estimated temperature reading, but it works incredibly well. I mounted mine on a tripod to make the image/zoom have less potential for stomach emptying, but handheld would probably work if it's been a while since you've eaten...
You saved me some money.
However, they do!
They don't focus to close range, I think my XP38 is 10 or 12 feet minimum. Finding the studs behind the drywall was done from the other side of the room.
I'm thinking about buying either a Flir Breach or a PVS14. Can't drive or walk around while looking through a rifle scope. That said, one very cool feature is that I can get a live view of what the scope is seeing on my tablet using bluetooth.
There's a video of some guys driving around with the scope mounted to the roof off their pickup on a motorized swivel base. They could drive down the road and see what's in the fields while viewing the image through their tablet.
my pocket2 finally arrived!
first impression: powers on quickly. infrequent calibration pauses. very easy to use interface. good resolution and refresh rate. love how similar to a point and shoot camera form factor it is.
will update with some example photos later after i figure out how to import them.
thanks again for the heads up y'all!!
super happy with this solar hardware diagnostic tool. ?
update: the hikmicro pocket2 seems to have no way on device to check how much space remains on the storage. alas!
Glad you got one, It's a very good thermal camera.
Absolutely amazing how the Chinese went from being so far behind Flir just a year ago to now being on Par with them in image quality and accuracy. They can thank DJI for that lol.
Enjoy
Enjoy
Thank you!
It is very fun to use in every day type situations. Pretty easy to see variations in walls that are adjacent to outdoors. Quite responsive frame rate. Very easy to operate. A joy to see the world in a new way. Feels like having x-ray vision or something. Unsure anything from FLIR performs this well at the same or similar price; have not actually checked (that company has a reputation for very high prices, and I did not want my hopes dashed, ha).
Now I just need to actually design, fabricate enclosure, and assemble my cells into battery packs, lol ?‍♂??️
