JoergK.
Here my thoughts on developing and building a sizable thermal generating & storage system
Some facts that direct my thoughts:
To carry this on, my heating systems run on a minimum of 70°F in the return and max. 100°F on the hot side. So, 100°F is a minimum, 200-220°F is achievable in the storage tank. A heat pump could be added to retrieve energy below 70°F, down to probably 10-20°F.
Questions:
Await your comments!
- I can produce heat and or electricity from sunshine, but not natural gas that fires my heating system right now
- My area (southern Alberta) has great sunshine hours year round and PV works fine, but like most, have no sunshine at night and less in the winter when we need the heat & power. On the electrical side, this is covered with a grid tied system, but one needs a sizable buffer, storage system for making thermal energy work year-round.
- I hope all agree that evacuated tube solar collectors are the best on the market right now to capture heat and, with 50:50 glycol mix work year round.
- I have 40 kWh of PV panels and can add the same size as evacuated tube solar collector, giving the potential of 650 - 2000 kWh/day (data from manufacturer)
- Problem is the collector size & storage calculation to not over produce, but set this so it works year round with minimal NG needed to buffer.
Questions:
- does this make sense in general terms?
- is it doable?
- how to calculate this all so I don't have anything overheat or freeze?
- is it viable over 25 years?
- Most could be done with own equipment & labor just the supplies need to be bought.
