wye001
Hi All,
I've inherited an old solar heating system and I need views/advice on how to improve it.
There is a thermal store that is charged from the solar collectors. This thermal store has a thermostat that controls a pump and valve that feeds directly into the underfloor heating. The valve selects between hot water from the thermal store and hot water from a combi gas boiler. The gas boiler is controlled from a thermostat in the house.
The gas boiler is new (An Ariston Genus One).
Question 1: Would it make sense and is it a good idea to connect the thermal store to the boiler via the heating return of the boiler?
My reasoning:
1. At the moment the two systems are not integrated. It's an either/or situation depending on a valve.
2. The solar part starts pumping hot water to the house whether it is needed or not and then the valve blocks the flow from the boiler. The boiler could be pumping water into the heating circuit due to the thermostat in the house and this flow is then blocked by the valve. This seems wrong.
3. I would rather feed the hot water from the thermal store into the boiler, which will need it if demanded from the house thermostats.
Question 2: So can new boilers handle hot water in the heating return circuit? If my flow temperature is say 40C and 35C water comes out of the thermal store, vs 10C water in the cold circuit.
Question 3: Should I have a mixing valve to mix the thermal store water down to something "safe" like 30C if the thermal store is at high temperature?
My reasoning:
