I plan to get an LP on-demand water heater for my off-grid house, and would like to add an electric tank water heater to pre-heat well water. I asked two on-demand brands about incoming water temps. Rinnai said their units require a minimum delta temp of 35 degrees, so an output temp of 130 would require an input temp of no more than 95 (to avoid excess cycling). Rheem said their units require a delta T of 30 degrees, so a 130 output would require an input temp of no more than100 degrees. I've looked at a few electric tank brands, all of which listed a minimum thermostat setting of 120 degrees. Any suggestions about a simple way to address this issue? Thanks in advance-
