Thinking of Designing a Solar Management System
fopoku2k2
I have successfully gone off grid. Fortunately i seem to have oversized my system. Batteries are fully charged by 11am. Sun last till 5pm on most days
I am thinking of designing an automatic system that would power on my air-conditioning when the batteries are fully charged. Anyone with knowledge of such a system or advice?
svetz
Works in theory! Practice? That's something else
Congratulations!
I don't know of anything COTS, but you could use something to monitor your SoC and then flip a relay to turn the AC thermostat from off to on (see the IoT). Here's another thread talking about similar things.
houseofancients
depending on your inverter, you could use home assistant , mqqt and sonoff switches and a heavy duty relay/contacter to switch your waterheater on.
i've been experimenting with a 200l pre heater.
in summer , it provided all the hot water we needed, in winter it kept my heating bill from the water heater considerably lower.
i would assume ac would work the same
fopoku2k2
I am using a Growatt inverter. Can you guide me through how you did you installation
houseofancients
not familiar with growatts.
you need to get your incomming solar in to a raspberry pi and into home assistant.
i use a second raspberry pi, connect with a serial cable to my inverter.
that second raspberry sends detail about incomming solar and my battery's SOC to my home assistant raspberry using MQTT.
i then put logic on both ( SOC > 90 and incomming solar > 2000 watts ) -> enable sonoff that controls power to water heater 1
if temp water heater => 65 celcius , shut down water heater
if temp pre heat tank < 65 enable heating element
this is using hass.io , node-red and mqtt
fopoku2k2
what does your second raspberry pi connected with a serial cable to your inverter run on?
houseofancients
lekeola
Thick our my tread, it will help out
Check my trend, this will help you monitor ur inverter and ur battery , manage output, and inputsz, check daily, monthly, years consumption, support parallel inverter monitoring, parallel battery like pylontech lithum etc , it's an in one software Solar plant monitoring
