I commented this on the video just now:
Hey, very cool video. Nice pictures too. Fun to watch.
How much current feeds into the lead acid to trickle charge them at high SOC? Have you tracked what happens with a shunt between your batteries over a typical night?
At low SOC, it would seem the lead acid is reducing the performance of your system. Considering that the LiFePO4 wants to keep the voltage high, you couldn't use most of the capacity of your lead bank. I suppose the bms could disconnect and reconnect, but the differing internal resistances disconnecting and reconnecting seem a bit scary (could hurt fets). I suppose the lead acid does act as a buffer. Hmmm.
I would have to see how they feed each other over a cycle. That is difficult to do without a data logging device. Have you done that yet?
I see, so small lithium battery, big lead bank. Hmm I suppose that is attractive for a marine system.
Have you done a full capacity test? How deeply do you discharge your bank? If you keep this bank at high SOC, and none of the cells short, it would probably work fine.
Good point about setting absorption at 14V. Very true.
The prices of lifepo4 are dropping quickly. I built a 280Ah 12V pack for $580 this week. That is cheaper than high quality lead acid, if coulombic efficiency and usable capacity are taken into consideration.
You should try LTO. LiFePO4 is touchy, but that is only if you do not have a BMS. LTO would destroy every downside of LiFePO4 you mentioned. You can discharge at 10C rate! You can start any size engine with a modest size pack. You would love them I bet. Everything you stated in this video screams LTO. I did try paralleling LTO and LiFePO4 some years ago, and it was horrible. My capacity test results were awful. LTO has a wider voltage range, and more linear. And my test results were awful because of it. The cells would feed each other constantly. Very inefficient. Trickle charging lead acid all night with lithium seems very inefficient. I suppose if your loads are small, you can do it. Just that difference in voltage at various SOC makes me cringe.
Do you have any data logged on how the batteries feed each other during a full cycle?? I would love to see it.
