This is super macro shots of how daly crimp their bms cables
Scph9002
Find it quite interesting how they just clamp the wire right ontop of the lug like as it was a bubble gum lol. Must be some tremendous force
It is a proper fused crimp tho. The crimped part of cable and the lug is one solid block of metal.
Dinky
Is that a proper crimp, looks like some of the wire strands have been abandoned/orphaned by this method?
Scph9002
yeah. But the diameter of the joint is thicker than the lug or cable anyway it seems :))
kenryan
I see how the cable end is formed into a solid block, but how is that block adhered to the lug?
time2roll
Photon Sorcerer
In pic #1 it seems a lot of strands are cut in the process. The wire end of the press die should be tapered/rounded a bit instead of a square edge that separated those strands. Probably works fine even if not pretty.
Scph9002
If you press 2 metals togheter hard enough they weld/fuse into one single solid piece. Kinda like clay
kenryan
Is there a term for this type of crimp? I googled "connectorless crimp" but did not find any info.
