I'm a newbie in this forum but I have messed about with electrifying sailboats in the past. It was awhile ago so my options then were lead acid. I have joined the four cells that I just received together and they're charging up. It's interesting to observe how lifepo4 batts charge compared to lead acid. The voltage is slowly rising but so is the amperage. It that normal for these types of batteries? I'm going to bulk charge them up to 14 volts or so and then use the Dr Meter power supply to top balance. So far the batteries are sucking up 8 amps. Seems to be holding there. The pack reads13.4 volts.
