sunshine_eggo
Happy Breffast!
I've downloaded the manual. Now all I've got to do is make myself read it.
If you have to force yourself to read something, read the guide.
Being retired and living on SS I went for the cheapest cells. I bought the B grade. Hope I don't regret it. I expect good things from Overkill. I have yet to capacity test the cells. So I don't know what the SOH is.Both are good choices and seem to deliver consistently.
By 'The guide' ? What's that?If you have to force yourself to read something, read the guide.
I've had my share of disasters caused by not waiting for the 'smart' guy to come help me. I burned up the motor controller on my sailboat electric motor conversion. 'Magic Smoke' ! I suffer from 'I can do it myself' syndrome. Sometimes I can. In spite of watching countless hours of videos I never picked up on that fact.. that a cell can over-volt real fast. No damage done I am fairly certain. I will set it up to slow charge with my Dr Meter power supply. First I have to figure out how to use it.Might as well upgrade the charge leads per the guide and get a few days of parallel charging with the power supply set to 3.65V BEFORE it's connected to the pack (per the guide).
With good leads, that's ~720Ah into them in the next 3 days.
And they will stay almost perfectly within 0.05V even if horribly imbalanced until the moment that one rockets above limit leaving the others below 3.4V. This might not happen to you, but it happens more often than it doesn't.
The voltage curve of LFP is so flat in the operating range (3.1-3.4-ish), cells at wildly different states of charge may read almost exactly the same voltage.
I received 9 EVE cells that varied by 12Ah in their states of charge (4.2% variation). This is a massive difference when talking cell voltage differences at peak charge. I've personally seen a cell SoC difference of 0.1% cause a cell runner.
Thank you. Those of us that have been hear awhile have seen too many posts with a tale of exceeded voltage and often bloated cells accompanied by, "are my cells ruined?" The answer is almost always "yes."
Are you using the wires and the alligator clips that come with the power supply? If you are you need to change them, it should be in CC mode (current set to max) right now if using the correct wires and terminals, there are many thread about not getting enough current while charging, I.E.I've got a power supply hooked up to the cells. They are in series. I'm charging at 3.55 volts. The read out on the Dr Meter says it's only outputting 2.34 volts but my amp meter says it's abut 4.7. I would expect it to output the max of 5 amps. Anyway it's top balancing. I have it set up so it is outputting constant voltage. That's correct, right ? I want to be sure not to over volt.
You know we're terrible -- you know the few that would check this thread to see how bad he damaged a cell or two
Yeah you're right. The stock leads are crap. But that wasn't the problem. I had to readjust the meter. Now output steady 5.2 amp. I did up grade the leads. Got carried away. I have three set of leads now. I checked the amps on the different leads. The amp output gets divided. That surprised me. I reckon it figures that it does. Volts stay the same. It was Will Prouse BTW, that suggested to make a 12 V battery and bulk charge it to 14 .2. So it doesn't take a month of Sundays to finish. I was reminded of that when I saw one of his video I'd seen in the past.That's why you read the guide where it tells you to upgrade the leads.
Remove leads. Set to 3.65V. Replace leads. Might hit 5A.
I upgraded the leads. The voltage reading on the Dr meter is correct. The voltage showing is not the limit it's set at. It's doing it's thing at CC. The voltage showing will- is rising as the cells charge. I'm going to turn it off when I go to bed, just to be safe. Not sure I trust this Dr Meter guy yet.Are you using the wires and the alligator clips that come with the power supply? If you are you need to change them, it should be in CC mode (current set to max) right now if using the correct wires and terminals, there are many thread about not getting enough current while charging, I.E.
BTW, set the Voltage before connecting the power supply to the battery.![]()
Thicker Wires Top Balancing makes huge difference!!
I made thicker leads for my Bench Top Power supply, and this made a huge difference while charging the batteries. Went from 3.6 amps in Constant Voltage with the tiny terminals that came with the power supply to 10 amps in constant current mode for the 10 AWG wires. This should cut down charge...diysolarforum.com
Would like to know how to make contact with Steve from technical support if you wouldn’t mind sharing ?The overkill manual also has some good explanation and examples supporting top-balancing. The how and why, and what can happen if you don't.
I still had to do quite a bit of bleeding down of high cells at high-knee - near full charge. I used a 12V headlamp bulb during the last few amps of charging to even all the cells up - right at about 3.55 or so. Even still, If I try to charge past about 14.2V or that magic 3.55Vpc or so, one will or more will tend to reach full charge and its voltage will shoot up - bms will shut down charging. Which is not a great way to manage your battery charging. So you set your peak voltage and duration on your charge source so it gets your pack to full charge without cells going over the volt max you've set in your BMS. The closer matched the cells are the more even they'll be near full charge - same can be done for near full discharge, but most don't need to bother with that.
Overkill by default sets nearly everything up for you and tests it. Another value-added perk for sourcing from them, plus you can call Steve for technical support if you have trouble. Try doing that with alibaba.![]()
Steve ? At Overkill Solar? You just need to send them an Email. They get back in a day or 2. I smoked a BMS 3 weeks ago. User error. My eyes aint what they used to be. Anyway, reached out to Overkill ... and on their direction, purchased a new replacement BMS, sent in the old burnt one and got a full refund. You can send it in and they will swap it out, but if you need it fast, it's best to purchase a replacement.Would like to know how to make contact with Steve from technical support if you wouldn’t mind sharing ?
