fmeili1
Solar Wizard
Thanks, just updated it.Code:MariaDB [Monitoring]> select max(EG4$Alpha$Vpv1), max(EG4$Alpha$Vpv2), max(EG4$Alpha$Vpv3),max(EG4$Beta$Vpv1), max(EG4$Beta$Vpv2), max(EG4$Beta$Vpv3) from EG4; +---------------------+---------------------+---------------------+--------------------+--------------------+--------------------+ | max(EG4$Alpha$Vpv1) | max(EG4$Alpha$Vpv2) | max(EG4$Alpha$Vpv3) | max(EG4$Beta$Vpv1) | max(EG4$Beta$Vpv2) | max(EG4$Beta$Vpv3) | +---------------------+---------------------+---------------------+--------------------+--------------------+--------------------+ | 536.70000 | 537.20000 | 346.50000 | 360.50000 | 323.60000 | 359.60000 | +---------------------+---------------------+---------------------+--------------------+--------------------+--------------------+ 1 row in set (4.176 sec)
Wow, you're using really high string voltages, even higher than the spec MPPT operating voltage range (120-500VDC) - but still below the max. of 600VDC
Have you seen any problems running string voltages over the MPPT max. voltage so far?
