justinm001
- Dec 18, 2022
- 1,959
Previously my RV was at my home plugged into shore and now its in storage. I also rarely use it and plan on leaving it in random campgrounds around the country for weeks/months at a time so need something as stable as possible. My problem is the 48V quattros use 80w at idle so 2kwh a day just to have 120V power in the coach. I have various automations to turn things on/off based on power so I can turn 120V appliances on when SoC is high and off when low which helps. Even with 5000w solar with rainy and winter its hard to get full charge of batteries. The system doesn't seem very stable and lots of components.
I'm wondering if I should add another pair of 48V batteries and setup the 48/12v DC converters then make sure the 12V is always topped off. Then maybe even change the inverters to turn off when below 20% SoC. This way the 12V will work on 48v and 12v. I also plan on adding a ATS and a lead acid battery to add a redundant system to keep 12V on.
Previously I had half the outlets running of the 12V inverter and the other half running off the 48V inverters. With 6 ACs and everything else I could pick the devices I want to run based on which system is charged. Then when on shore AC power ran from the 48V to the 12V and charged both systems and all outlets.
48V SYSTEM
Currently I have 50A shore connecting to 2x quattro 48v 5000w in split phase. Also a 20KW genset set to 240v/80a I rarely use. Running 2x 48v SOK 100AH rack batteries for 10KwH. This connects to my main breaker panels using 4ga wiring so can run 100a without issue.
48v Solar:
6x320w panels plugged into 150/100 MPPT (driver)
6x320w panels plugged into 150/100 MPPT (pass)
10x100w panels plugged into 150/35 MPPT (middle)
12V SYSTEM
2x100w panels plugged into 100/30 MPPT running 2x12V EG3 400AH rack batteries for 10KwH. I have about 500w or so 12V load with wifi/cell, lights and other RV stuff.
Other parts
separate genny 12v battery with 120V AC charger to keep topped off.
120V AC charger for the 12V system
12v quattro 5000w for the 12V system but its dead and need to RMA it. Not sure if I should use it.
24/12 and 24/48 DC DC converters to charge from alternator (1500w to each)
2x 48/12v DC DC converters 20a each not used
Both systems have CerboGX, shunts and everything else.
The 48V is in a bay 30ft from the 12V and I have 1 4gauge wire coming from the 12V to 48V bay (used for the alternator DC converter). It'll be a huge pain to run more wires but possible.
48V SYSTEM
48v Solar:
12V SYSTEM
Other parts
