I have a 12 x 20 off grid cabin I have been building on and off for about a year. Very excited about solar power and ready to make the investment in batteries, panels, charge controller, etc. Been studying Will's videos and projects for a couple of years now. Amazing and inspiring. I am a Mechanical Engineer in the power industry with basic knowledge of wiring and power generation. I have done some home wiring with 120V AC but I have never done DC. Would like to get some thoughts on compatibility between the major components before I make the investment.
I plan to run a DC air conditioning unit once in a while in the summer. Other than that just charging a computer, small electronics, and a few lights the rest of the time for load. Have a wood burning stove for heat. I am looking at the Hot Spot Energy DC48 Unit. The direct DC unit is very efficient. Curious if anyone knows of a different model. This is the only one I can find.
Running some basic numbers for charge per day based on 6 hours I was thinking of two strings of 4 panels 440W / 50 VOC / 11A (each string) in (two strings) parallel for a total output of around 200VOC at 22A. I think that would be a good fit for a Victron 250V, 100A MPPT. For batteries I like the SOK server style units 48V 5kW. I was thinking two in parallel for about 10kW storage.
With the cabin being off grid I am concerned about the inverter running a lot while I am not there – hence the DC air conditioning unit. I would like to set up the system so it can charge and the air conditioning unit can run a little to control humidity and keep the cabin temp at or below 90F to preserve the batteries. That would require a bus in the 48V range to power the air conditioner and an inverter for 120V AC loads.
I like the Victron setup with the Lynx shunt 1000 and Distributor 1000. I don't have the fusing or breakers laid out yet but I have a diagram with the major components.
Looking at the spec sheets the air conditioner operating range is 46-59VDC, the battery charging voltage is 57.6-58.4VDC, and the Victron inverters show an input voltage of 38-66 VCD. Not sure how sensitive the air conditioning unit is or what type of fluctuations come out of the MPPT. My only concern looking at the specs is that the battery charging range is within 1 VDC of the top end of the air conditioning unit. I don’t have any practical experience to know how much the system voltages fluctuate.
Any thoughts would be greatly appreciated. Layout and spec sheets attached.
