Thoughts on this panel?
moonlitsouls
Seems like all the panels made for RVS are a lot smaller for obvious reasons but what are the pros and cons to using something like this instead?
Was thinking of adding a panel to the side of my RV that I can retract like an awning. I could potentially mount it using j brackets and have a swivel made to allow my to post it up toward the sky. What do you guys think about this panel here? I found one on Craigslist
If I wire this to my battery through it’s own 75v 15a SCC , I can add it to my existing arrays with no problem correct ?
Adam 79118A79-CDE8-4CA7-BDD9-4294FBE91193.pngA4DEF3AA-D119-4E36-B72A-CE35E6351380.png30BD5549-B70F-47D5-9696-BAFE07810BEE.png
Lots of folks use large panels as they can be significantly more cost effetctive.
Seems like a good panel.
Yes.
They make great awnings. This is a 200 watt on it's own SCC
It's half the size and weight of what you are thinking at just 25lbs. I can handle it ok to swing it up, but to swing 25lbs above level on the end of a stick is a little bit of a handful. I do it all the time but I'm not sure I would want to do it with 50lbs
That said, I'm thinking of doing two more on the drivers side
that is awesome , what are you using to secure it down to the bottom side when you're on the road?
I use the same bracket that holds the prop rods to secure it using the large plastic wing nuts
Although I did lower the panel once and did not engage it into the lower supports, got distracted , and then drove off for a 50 mile run down the freeway. I asume it was flapping in the breeze back there but I could find no damage when I discovered the issue
