MorganCarey
- Jul 19, 2020
- 49
Brand: | LG |
Model: | LGABD21865 (INR18650D2) |
Capacity: | 2950mAh Rated |
Voltage: | 3.64V Nominal |
Charging: | 4.20V Maximum 1475mA Standard 2950mA Maximum |
Discharging: | 2.75V Cutoff 590mA Standard 4425mA Maximum |
Description: | Blue Cell Wrapper White Insulator Ring 18650 Form Factor |
These are Li-Ion batteries.
I have the opportunity to get as many as I would need for my project free of charge if I want them.
I would like to build two 12V 200AH batteries. They will be used in a 1kw off grid setup to power a 12v 1500W inverter currently. At some point will be swapped over to 24V.
I have never built my own battery before.
I currently have a drop-in 12v lifepo4 which is nearly worry free.
Should I be concerned with the Li-Ion chemistry. Should I stay away from it? I have visions of tesla fire at the cottage.
