RoadTurtle
- Mar 30, 2022
- 425
Currently 2 strings - three panels of 200w on each string mounted flat to the roof. Roof curves both laterally and longitudinally, making using mounting rail challenging. Currently have common z-brackets mounted on the end of the panels. 5th wheel is facing due west, and this is our permanent snow bird home. Late Sept to late Apr.
As I've been pushing my system beyond my original design constraints... I need MOAR
Unfortunately do to a lot of junk on the roof, I'm very space constrained, and already at legal height, so can't go over the junk either.
Two questions, and I prefer to reuse existing roof holes, rather than creating more potential leak points.
1. given my winter latitude of 34.5N, does a panel angle of 45 degrees make sense? If I used the exact same configuration, drivers side would be an estimated 50 degrees, pass side would be estimated 40 degrees. Is this a good plan to carry through the deep winter months?
2. Thinking about getting right angle aluminum and drilling holes in it to match the existing roof holes spacing to replace Z brackets. South side attachment would be set up as a pivot, north side, would either be flat on the roof for travel, or boosted 45 degrees with either flat stock (small angle aluminum). The right angle pieces pieces mounted to the roof would probably need to be 2" raising panels up slightly so as it pivots, the edge will clear the roof.
Below is the current configuration
