Have been running a SunGoldPower TP6048 split phase hybrid inverter with 2.7kW (ground mount) PV array and eight 100Ahr LiFePo4 in series/parallel (48V) for about 1-1/2 years now. Inverter is grid tied, not grid feed and system is working fine. Currently building second 2.7kW array and wanting to replace the TP6048 with a 12kW inverter with the same features and connections. First Question: Opinions/experience regarding replacing 6kW inverter a with bigger one versus adding second identical TP6048 in parallel. Significantly cheaper to add 2nd one in parallel but will I regret doing that for some reason? All the labor is DIY (me) so not really a factor either way.
Second question: Are there quiet inverters for sale? Under heavy load the current TP6048 is disturbingly loud and MUST be mounted in an attached garage. I've eliminated external causes and am considering opening it up to see if the fans are having issues but don't want to void the warranty so gotta talk to SGP about that. I'll have to get a db meter to quantify it but it's at least as loud as an old timey vacuum cleaner. What's your experience with noise levels of various brands of inverters?
