ArthurEld
Solar Wizard
I'll order the MRBF mounting bar and some 100 amp fuses.
I already have the cell terminal mount ones and 125 amp fuses.
Code:charger+fuse|+cell_0.0-|+cell_0.1- f f u u s s e e |+cell_1.0-|-charger
This ought to be a safe test
Pardon the stupid question ? but how does one read the code ?Yes, but I can predict you will blow the fuse on the right instantly.
Its not a codePardon the stupid question ? but how does one read the code ?
BiduleOhm, how do I check for a short without making sparks?Yes, but I can predict you will blow the fuse on the right instantly.
I made it up.smoothJoey, is that code something you made up or is it something widely used?
I assume you are some type of computer programmer.
legend {
+ { positive pole }
- { negative pole }
| { parallel connection point }
n.N { 2 dimensional array where n is parallel and N is serial }
2 cells in serial
I don't think this will short
+cell_0.0-+cell_0.1-
2 cells in parralel
|+cell_0.0-|
|+cell_1.0-|
2 cells in serial and 2 in parralel with a common cell
I don't think this will short either but I think @BiduleOhm thinks it will short
|+cell_1.0-|
I should have looked it up instead of asking. I need to use the resistance or continuity test on my multi meter.BiduleOhm, how do I check for a short without making sparks?
edit: or without blowing fuses
I made it up.
Some people get it, most don't .
Its still evolving.
The last set is is a bit aberrant.
|+cell_1.0-|
They are separate physical cells.If cell_0.1 and cell_1.0 are actually the same physical cell then you have a short, guaranteed.
I have never worked with a resistor. I see them mentioned often so I guess I better learn to understand them better.1st solution: measure the voltage between the two wires you want to connect: if it's different from 0 then you (might)* have a problem. Use the low impedance mode of your DMM if it has one. * DMM are very high impedance devices and ghost voltages might show up and make you believe there's a problem when there's not.
2nd solution (better): put a resistor (a few kOhms for the majority of cases is fine, for high voltages you need to increase the value) between the wires you want to connect and measure the voltage across it (or the current going through it): if it's different from 0 then you have a problem.
I would like to do a quick test before tossing a busbar onto the studs. Shorts are probably a good argument against using studs.
I will play around with my mutimeter to see if I can easily detect a short. I will start researching resistors too. But I need something simple and quick. I see Will confidently tossing busbars around. I am not that confident.
It's all Greek to me - I cannot even manage Python Too old to learn new languages. I am as confused as Zingy , your pet elephant.I made it up.
Its still evolving.
That's Schmingie and he is reasonably savvy with these things.It's all Greek to me - I cannot even manage Python Too old to learn new languages. I am as confused as Zingy , your pet elephant.
Tempest in a teacup, cool.Ok, then it's perfectly fine
