Hey all, first thread, thanks for any and all help.
I built a tiny home over the last year and built it to be off grid. Wired half the house in 12v and the rest in 110v. I hired a guy to build a power wall and help me size and wire my solar power system. Long story, short, he burned up a good chunk of the batteries, didn't fix the problem, gave me all of it incomplete, including the burnt batteries and didn't help me with what to do with it. So it's up to me to build the system. I have only a beginners knowledge of electricity. I understand volts, amps, and watts, as well as wire sizing, a little bit of fuse sizing and somewhat of a grasp of all the components of a solar power system. But I have no idea how to finish this system. First thing is the batteries, I don't know what they are, the guy found them for a really good deal. Each pack has 9P3S of Panasonic NCR18650. Please correct me if I'm wrong. Which if I am right is, 12.6V, 26.1ah and comes with it's own BMS. Supposedly it was used for medical purposes. Here's a picture:
And the BMS:
Bit ugly, but you get the idea.
Here is a picture of the battery box built by the guy.
One of these batteries almost caught fire when he hooked them all up, in parallel, to balance charge them. His guess was that the BMS malfunctioned and kept the voltage lower, so all the other batteries began to send too much current to this one battery, thus fire, or almost fire. Damaged 11 of the 32 batteries. I'm wondering if that is correct or not. Could he have somehow hooked up the batteries wrong? The connectors plug goes into +1 -2 +5 -6:
Yet if you look at the solder joints, it say Red Pack + is 1 and 2, and Black pack - is 3 and 4. I don't know how BMS's work so maybe it doesn't matter, but with a multimeter I wasn't getting any voltage getting a reading of .35 volts from terminals 1 and 2, as well as 5 and 6. If I tested the solder joints, it says this battery has 10.5V. So was the fire caused by a malfuctioning BMS or the way the batteries were hooked up? And what would be the solution to prevent this problem from reoccurring? I can provide pictures or more tests if needed. Thanks for any and all help. I will have many more questions, but starting at step 1.
And the BMS:
