svetz
Works in theory! Practice? That's something else
How do you clean your panels? Got a tip for cleaning or maintaining panels? How do you deal with tree sap, gunk or other corrosion that happens?
Post it here!
In general panels at greater than 10° tilt are self-cleaning [ref], but even then they might need the occasional cleaning. So...
How to clean your solar panels
Ammonia Alert
Before cleaning your panels with an ammonia based product (e.g., Windex, Sprayway) check the datasheet.
Not sure how serious it is, but I know panels have certifications for ammonia ratings (typically most important for farms where fertilizers are used).
Reference: www.powerfromsunlight.com/the-most-important-ammonia-corrosion-resistance-standards-for-pv-solar-panels/; so that makes me think ammonia would be bad for some panels.
Thermal Shock
I've seen numerous warnings that cleaning by hosing them down should only be done while the panels are cool to avoid thermal shock.
Coatings
You might also be interested in: https://diysolarforum.com/threads/water-repellent-coating-for-solar-panels.131
Post it here!
Ammonia Alert
Thermal Shock
Coatings
