OffGridForGood
Catch, make or grow everything you can.
I have no experience with factory-built racks, I prefer to build my own from unistrut /steel/timber to suit the purpose and location I have.
- I Agree with OzSolar - You may regret installing too close to the ground.
If you do go with the bi-facials keeping them raised above the ground will increase the benefit of that type of panel.
To me, a raised set of panels should be an opportunity to get a seconday use - shade, storage, rain-harvesting, cooling effect for something else - place to park a car? If you spend the money to build a raised surface for the PV, why not also get a useful space under the PV for something else you need? {I built a 26'x26' carport this fall, for two vehicles, but it's "real" purpose is to support my next PV expansion in Spring 2023}
One caution: if you build a raised PV support stucture, be sure you carefully consider wind loads including up-lift forces.
Hope this gives you some things to consider.
