Still researching my home solution to offset some grid cost with PV and have a battery backup. I am looking at Outback and Schneider exclusivly simply because of surge power, true UL listings and was planning an off gird build with grid passthrough (mini-grid setup) which would also allow inverter to charge batteries if needed. Then I went down the hole of grid tied, micro inverters, optimizers, etc and truly see the advantage and ease of wire runs with AC vs DC for the PV. Basically I'm stuck in my mind. I could get a ok Grid-Tie system for the price of some good charge controllers and have an easier install with off-grid inverter/battery. Again goal is to use Grid when required, no interest in sell back as power company will only buy back for max of 2 years. Any thoughts no my ramblings? Max array size will be 10Kw and I already have my critical loads panel circuits wired and critical load panel wired to main panel to code for the time being.
