If you look at the EPVER user manual, the max Panel power is 1.5 times the rated charging power of controller.l.
You will not get the Wattage from panel in the real world any way.
Read page 8:
2) Maximum PV array power The MPPT controller has the function of current/power-limiting, that is, during
charging process, when the charging current or power exceeds the rated charging current or power, the controller will automatically limit the charging current or power
the rated charging current or power, which can effectively protect the charging parts
controller, and prevent damages to the controller due to the connection of
over-specification PV modules. The actual operation of PV array is as follows:
Page 9:
According to “Peak Sun Hours diagram”, if the power of PV array exceeds the rated charging power of controller, then the charging time as per the rated power will be prolonged, so that more energy can be obtained for charging the battery. However, in the practical application, the maximum power of PV array shall be not greater than 1.5 x the rated charging power of controller. If the maximum power of PV array exceeds the rated charging power of controller too much, it will not only cause the waste of PV modules, but also increase the open-circuit voltage of PV array due to the influence of environmental temperature, which may make the probability of damage to the controller rise. Therefore, it is very important to configure the system reasonably. For the recommended maximum power of PV array for this controller, please refer to the table below:
