MountainmanBill
- Feb 20, 2021
- 69
I live in a forest. The opening in the canopy only allows for about two hours of direct sunlight on my nine 275-watt panels in the dead of winter. I also had ten 100-watt panels in the system but some very strong winds took down their not-so-strong support I made for them. They didn't produce much power anyway. Six or seven amps at best. I have 8 L16 400 Ah batteries connected for 48 volts. The most power I was able to produce in the dead of winter, on a clear day, was around 5,000 watts (with the 100-watt panels included). With the sun getting higher every day, a few days ago the system produced 8,000-watts that day (without the 100-watt panels in the system). The system was producing 40 amps during peak sunshine. So here's my question, and some thoughts:
Batteries can accept only a certain amount of power to charge safely. The battery label says their maximum charging amps is 70 amps. Is that 70 amps per battery or 70 amps per battery bank?
I was thinking of ditching the 10, 100-watt panels for 9, 300-watt panels. That would give me 9, 275-watt panels and 9, 300-watt panels in the system. And also adding another 8- L16 batteries to the bank for a total of 38,400 watts of storage capacity. I would have a lot more power to charge the batteries, but a lot more batteries to charge. Is it six of one and a half dozen of the other if I upgrade like I mentioned? The battery bank I have now just doesn't have the storage capacity to get much use out of it if I want to keep them above 50% SOC, which I do. I don't even like going that low. An electric heater kills the bank overnight. Doubling the bank's capacity would help a great deal in this regard but do I have enough sunlight to charge them fully during the day with the limited amount of sunlight I have? During the height of summer, I can only get about four hours of direct sunlight on the panels. The rest of the day is only indirect sunlight; filtered through the trees. Maybe 10 amps with the 275-watt panels, on average, for most of the day. I would get 20 amps, wouldn't I?, if I added another 9 panels. Double the amps but also double the batteries to charge. So is it worth it for me to add another nine panels and eight more batteries? Would I even have enough solar energy to recharge that big of a battery bank in a single day?
Thoughts?
Thoughts?
