I know very little about solar, so if I am asking some dumb stuff here, that's why.
I have a 12V system that was installed 10 months ago for a detached garage. I have a Windy Nation P30L charge controller, two 100Ah AGM batteries, one 100W PV, and a 1500W PSW inverter. So if I draw down to 12.2 volts (50%), I should have 1200 watt hours. (I am adding two more batteries and three 100W PVs next weekend).
When the system is fully charged and I plug in a 390 watt appliance, I can watch the voltage drop. In 30 seconds it's down to 12.2 with the PV generating 2-3 amps, and then it (battery voltage) recovered and bobbled between 12.2 and 12.3A.
That seems pretty quick. I thought with 1200 watt hours I could run it for 3 hours! In addition, the battery health indicator goes from 5 windows being filled it to 4. (See photo. I'm not sure what the relationship is between battery voltage and battery health).
Before I bought the second battery last year I accidentally discharged the first one below 12 volts. I hope I didn't wreck it.
When I added a second battery I didn't notice any change in performance.
It is set for balanced charging.
Some questions:
1. Is that quick drawdown normal. and will it stabilize at 12.2V?
2. Did I damage a battery by letting it drop that one time?
3. What is 50%? Is that 12.2?
4. Low-voltage shutdown is set to 10.7. Isn't that way too low?
5. Is it safe to drop to 50%, or should it be only top 60% (12.3 - 12.4V)?
Thanks.
Some questions:
Thanks.
