I'd do anything else before having to put new, possibly problematic/incompatible MC4 connectors on.Do you coil them up with zip ties or shorten them with new mc4’s
fortunately, the panels I got only have 250-350mm of cable length, just enough to connect the next string in series with almost no slack.Hi all what do you guys do with the spare cable between panels? Do you coil them up with zip ties or shorten them with new mc4’s
Ah yes those are MC3 connectors, not as problematic as MC4 in my experience (i actually prefer MC3 for temp/portable arrays.Can you show some picture of incompatible MC4 connectors?
I thought they are all the same?
MC3
Yes, coil them up and tuck them so they are not dangling. I only have 3 x 100W panels so it's not too bad.coil them up with zip ties
I believe this is one of those times that theory is one thing, and the reality of a situation is another.No circles or loops at all!
Oh, wow. I did not know this. Thanks!NO COILS IN YOUR DC WIRES!
No circles or loops at all! (collectively referred to as loops). Run the wires straight out and then back to where you want them, making sure that they are kept parallel, "S" shaped or "U" shaped. Keep your positive wires as close to your negative wires as possible - bundle them together. And make sure you do not create a giant loop by running your positive to one end of the array, and your negative around the other side of the array to the other end. Pos and neg should always be bundled together. And interconnects must be un-looped and run out and back in a "T" shape. Use frame clips and/or zip ties to keep wires close to each other.
Loops are inductors that can act like a transformer or antenna and pick up stray electrical noise. It can introduce high voltage spikes into your DC system. It can burn out MPPT inputs and/or make your charge output unstable. If lightning strikes a few miles away, it can induce huge voltage in your PV wires if there are loops in it, and blow things up in a jiffy
Uncoil all wires and lay them out straight, then fold them back to where you want. If you can handle the work, clip the connectors and extra wire off and crimp new connectors to the shortened leads.
The PV wires running back to the house should always remain bundled together. And whichever one runs out to the far end of the array should follow the path of the wires and MC4 connectors between the panels. Literally zip tie it to them.
This is also true for your battery and inverter DC cables. Pos and Neg should be bundled together and kept parallel wherever possible. It improves surge handling and reduces noise from your own wires that gets created by the inverter. Never loop the extra wire, if your battery cables are long on some of your batteries. Lay (stuff, cram, jam) them into a "S" shape.
Three cheers for being lazy and strewing them about randomly on the roof!NO COILS IN YOUR DC WIRES!
Bigger the transformer the fewer the turns.A few coils will have little if any effect, unlike a full blown 500' reel of wire. How many transformers have you seen with 3 wraps of windings, now if there were 200-300 coils around an iron core might be different.
I had to think about this one.PITA
