I have a new Duromax 13000EH generator. Using propane, its output is
41.56 amps
@240v. I confirmed with Duromax that the generator will not reduce amp output if I connect it to a lower load such as the EG4 Chargeverter with its maximum input amps set for
26 amps
@240v; therefore, I'm assuming that the chargeverter will be overloaded. In lieu of buying a smaller generator with lower amp output, is their another solution available that would allow me to use the larger generator? Although I'm at the novice level, I plan on buying EG4 batteries and inverters to install 100% off-grid energy on my 38.5 acres of raw land here in Arizona. Since I will not be on the grid, I need a backup solution to keep the batteries charged in case of extended inclement weather. Any advice is much appreciated.
