Top 5 Reasons for Solar Tracking (w/rebuttals)
Mark MacDonald
What if there was a technology that could increase solar panel output by nearly 50%? Everyone would be super excited. Oh, there already is a technology that does that: solar tracking.
We've all seen the fields of commercial arrays with solar trackers following the sun, some dual-axis, most single, and yet outside of the utility scale applications common wisdom presumes that solar tracking is too much trouble and it's better to just buy as many PV panels as you can..
I'd like to explore the issue a bit deeper and present some of the positive considerations for application of solar tracking for residential/off-grid applications and common rebuttals in favor of fixed mount arrays (in a somewhat sarcastic manner, hopefully for your amusement).
Pro #1. The big obvious: get more power. Up to nearly 50% more with dual-axis under ideal conditions. The power curve is much more flat like a mesa top instead of a camel hump as well. If you're grid-tied, then your utility thanks you for the wider power curve, and if you're off-grid, then your batteries thank you for the extra float time before you start discharging them again.
Rebuttal:
Under cloudy conditions solar tracking can be useless. Me buy more panels. More better.
2n'd affirmative: Forgive me, but I consider this the brute force and ignorance approach.
Solar panels can be useless under cloudy conditions, that's not a rebuttal! Tracking still benefits from the sunny times. In fact, it makes the good times better. A very common weather pattern is a cloudy day that finally clears up in the late afternoon. Fixed PV panels will sit at an inefficient angle, but a solar tracker can easily deliver twice the wattage in these conditions and might be able to actually quickly float your batteries with those last hours of sun.
Also up for consideration is the available area for roof mounting of PV panels which could limit the ability to simply add more panels. Certainly this is not a given.
2. Incremental cost increase for ground mounted arrays for solar tracking can be a negligible project percentage compared to performance increase.
It's illogical to just compare the PV panel costs when calculating power, much less ROI. Assuming for the sake of this point that we don't address roof mounted panels, the construction materials and labor for footings, trenching for cables, assembly and installation of a fixed mounting system and PV panels requires only minor expenses to allow for movable joints and electro-mechanical hardware to perform solar tracking.
Rebuttal:
Yeah, but it's still complicated and can be unreliable, better to just use more PV panels
2n'd Aff: It is true that not everyone is qualified to engineer a tracking system, and even trying to install an engineered system can be bewildering to those without experience with electronics, motors, and DC as well as AC electricity utilization; however, this is all solved by research and educations, as well as utilization of qualified personnel and equipment, as with all things.
Additionally laying more panels is all fine and dandy in flat desert or open plains, but lots of people (outside of the cities) live in wooded and mountainous area where the roof of your house might not even be the part of the property that gets the most sunlight (ever live in the redwoods?). In those case you may need to maximize the production you can get from the area that does get sunlight and a solar tracker is ideal for that.
3. Roof mounted systems may not be feasible for existing structures, and also pose a number of issues including fire hazard.
A ground mounted solar tracker eliminates any structural or mounting issues with existing roofing systems, and by situating the solar panels in off the ground in a clear open area (for sunlight exposure) fire-hazard is also greatly reduced.
Rebuttal: Fire hazard is low enough you don't have to worry about that, and who cares about solar for houses with funny pitches and roof types?
2n'd Aff: Um, yeah, ok.
4. Renters may not be able to get permission, or want to place pv panels on a roof. Tracking mounts can be disassembled and moved, or even built on trailers for ultimate mobility and utility.
Rebuttal: I own my home and I don't care about that, it still sounds hard anyway.
2'nd Aff: But it's a great option for those that need it, and could also apply to Tiny House owners and RV'ers as well.
5. It's a freaking robot! It sleeps at night, wakes up in the morning, follows the sun, and collects power for your house...how cool is that?
Do you by clothes, cars, phones, or most of the other things in life without considering how they make you feel?
If you have a solar tracker system, guests will want to see it, and you will want to show it to them. You will feel pride of ownership.
If you have passive panels on your roof, you'll probably forget to talk, or even think about them.
Rebuttal: Silly nerds.
2'nd Aff: Long live the nerds.
Check out homecsp.com for more information about solar tracking and my line of solar tracking controllers .
Me buy more panels. More better. Panels have no moving parts, they don't need to be greased, they don't have parts that wear out, and are cheaper than one of the solar trackers that you sell. I realize that you have a financial interest in the trackers, but the rest of your arguments just don't hold water, in my opinion.
#1-add 50% more panels to get 50% more power. Cheaper, and you may get a tax rebate to boot.
#2-it's even more of a negligible cost to buy more panels. Again, cheaper, will pay for itself faster, more system redundancy.
#3-a poorly installed system poses a fire hazard-it makes no difference where it is. You argue for a ground mounted system, which I personally prefer, but that has nothing to do with a tracker-you don't even mention a tracker in this argument.
#4-Renters don't install solar systems. If they do, it's going to be something portable. Again, this argument really has nothing to do with tracking.
#5-So basically you can brag about your tracker at a cocktail party? I actually don't consider how any of my components "make me feel". I care about how they work and their longevity.
Summary-I don't see a single point above that provides a benefit that trackers have over overpaneling.
I went to your website to try to assemble a package to compare prices against additional panels, but apparently you must already know everything you need an how it goes together, because everything is a la carte on your site, and I have no idea what I would need. I'd suggest at least putting together a package for people to buy.
Please, prove me wrong!
Well, here in Western Washington on the west slopes of Mt Rainier I found solar tracking a must. Trees to east limits me to 5 hours in the winter. Mounting panels on a polar mount configuration is simple and 16 cycles @ 9.2sec every 15 min works well. Can’t use the sun for tracking around here.
Solar Tracking is more efficient no matter what you do.
Unfortunately in our economic situation, money is a huge deciding factor.
I can spend $1400 and get a 2 axis solar tracker, that can support 6 panels.
I can spend about $300 and get a single axis manual adjustable and angle the panels, or about $200 and get a mounted panel stationary.
I can spend $1000 and get 12 more panels (3kWp).
It's always a tradeoff.
Take away the money tradeoff, and the dual axis sunflower copying solar tracker wins every time.
Pro: If you have your panels on a ground mounted tracker, and can put them in a nearly vertical position, cleaning them is much MUCH easier because you don't have to try and fight gravity with a 20 foot pole, rather you can use a ladder and get a much better clean on them.
This statement is based on my container mounted panels - They were only one row tall so a squeegee with an extendable handle covered them quite nicely in this vertical position. It's quite tough with my container mounted system to set up a ladder if they were just in the flat position.
