Squeezer04
- Dec 7, 2021
- 11
I just purchased a 30 volt 30 amp variable power supply to use in top balancing a 4S 12 volt 200AH LIPO pack. It is my understanding that I should set the power supply to 3.6 volts and when amps go to zero (or close), I’m balanced. With the batteries not connected I set the output of the ps to 3.6 volts. I connect the batteries and the output of the ps drops to about 3.4 volts. If I then slowly increase the volts output adjustment the lights on my ps switch from constant voltage to constant current. Is it OK to be in constant current?
I’m obviously new to this. Be kind.
Thanks
Thanks
