The value i’m adding is to let the original poster know that fixing the issues he’s having right now with regard to the way his system handles an imbalance will result in less stress over the duration of his system life.
He doesn't have a system yet. He is asking about what to do with his new cells.
Fix the way the BMS handles cell balancing so that it won’t be an issue in the future - OR, bandaid the cell balance and repeat as required by manually balancing the cells multiple times as the system ages.
are you just going to pound your chest about "bad design," or are you going to give the answer?
I’m already seeing a lot of people asking how to stop their one or two year old battery (that was initially top balanced) from disconnecting while charging. What does “the guide” recommend for that?
Guide is specifically for manually top balancing. It's strongly implied as the first step for a new battery.
Again, are you going to divulge the tightly held secret of design, or are you just going to dance around it?
Here's my "good design":
Set BMS to balance at or above 3.40V, 20mV deviation and only during charge.
Charge to 13.8-14.4V
Float at 13.6V
If your cells are good, they should never go out of balance under typical operation. If they go out of balance, you may need to re-top balance, or you may need active balancers, or you may need new cells.
Wow I didn't mean to start such a big discussion with all these heavy hitters, but I really appreciate all the information and feed back in this thread.
I was referring to this video
@ 1:35. Where its stated they will naturally balance over time, but it may take weeks or months.
@Will Prowse
I retract my statement.
@Will Prowse is wrong in that video - at least based on the auto CC generated text.
These cells are
supposedly
- Brand New, Grade A Cells
- Matching Voltage, Capacity, Internal Resistance
I bolded the key word. that's the tough part. Dozens (hundreds, thousands?) of people have been told that they are getting primo, top notch, grade A, matched, balanced cells of pure awesomeness. Sometimes it's true. Sometimes it's almost true. Sometimes it's close enough to true that you don't get mad. Sometimes, it's such an egregious lie, it makes you want to punch babies.
You won't know until you receive them.
Follow the guide. If you charge to full without issue, no top balancing is needed. Top balancing may not be needed, but may have to change the way you use your battery until the BMS can passively balance to an acceptable degree... which may take weeks or months.
Its only going to be 1 small 4S pack, however I already ordered 16 more cells, to put together a larger 48V bank
Even with the same supplier, you may find your 16S cells might be different from your 4S cells in a non-trivial way. Since you're building two separate batteries and not mixing them in the same battery, it shouldn't be a problem. You may find that your 4S pack goes together perfectly with no balancing needed... but you may find that your 16S pack needs to be top balanced... or vice versa.
