Hello,
I have just put together my first battery using 2 x 24V batteries (48V system) from SS that are welded in series, so I cannot balance each cell individually which is typically described. I am using a JDB BMS (48v 16s 100A) and Growatt 3000 LVM TL and am wondering what would be a reasonable way to top balance them?
I don't have a 48VDC charger but could I adjust the settings (JBD and/or Growatt) to charge the batteries up so I can then use a benchtop system to top up the low cells to 3.65V per the Overkill BMS manual's suggestion (see below)?
Thanks for any advice.
