Sunnytheskoolie
- Feb 12, 2021
- 60
Hello,
I have been running my battery for the last 4 years and it has started to have some issues. When reaching the upper limits it starts to have cells that charge faster and others that charge slower. There are only 2 or 3 of the cells that drop down, most of them stay together during the charging.
I am running the REC Q1 BMS, I do not have an active balancer on it.
Everything was running fine for a couple years with the right BMS settings.
I just pulled the battery apart, it's a 2p16s battery. I top balanced it to 3.65v last night and am going to let it sit for a few hours/day to see how it settles out.
Should I put the cells back together in the exact same arrangement or should I mix up the parallel cells?
Should I also bottom balance the batteries as well?
I used a small charger to get the batteries to the same voltage when the pack was together. 80% of the pack would be at the upper limits and then the system would go into an absorption state and the BMS would start trying to balance it all out. I would take the small charger and put a charge into the cells that were lower so that they would climb up to meet the other cells. I would repeat this process until all the cells were at the top 3.5 limit I had them set at. Then the pack would stay together. It was just from 3.37-3.5 that they would split.
If they still separate like this I will go ahead and add an active balancer since it seems like it would keep the cells together while charging. I think the cells are all still in great shape after pulling them all apart.
Any advice or if you have done the same thing please let me know the results.
Thank you
Thank you
