Hi
I ordered 16x 320ah cells liitokala from AliExpress
I'm in the process of trying to charge them. I plan on doing 2x 8s 24v banks but I'm charging them with a 12v charger first in 4s with a JBD BMS. Here are the voltages so far before they got cut off from the BMS.
When they arrived they were all 3.29v.
This was the voltages after I had noticed the charger had terminated the charge. (Probably from the BMS cutting off the charge)
Batch 1
1. 3.365
2. 3.575
3. 3.373
4. 3.491
Batch 2
5. 3.372
6. 3.397
7. 3.573
8. 3.377
I'm in the process of charging the rest. It seems there's a high voltage or low capacity cell in each batch that's affecting the others.
The voltages for the cells have now dropped to 3.34v besides one that is 3.37 which was the 3.575 cell.
Batch 3 which is in the process of charging also shows a 0.2v difference between the highest and lowest cells.
Is this typical for AliExpress cells? Are they repackaged used cells?
So what should I do now?
I will charge up the third and 4th batch.
Do I recombine the cells to exclude the low capacity ones and charge them in 4S?
Do I then put 16 cells in parallel and set the voltage for 3.55v? Or do I seperate them into 2 sets of 8 cells each in parallel with the low voltage cells in one and the high voltage cells in the other.
Batch 1
1. 3.365
2. 3.575
3. 3.373
4. 3.491
Batch 2
5. 3.372
6. 3.397
7. 3.573
8. 3.377
