Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,632
It seems clear that holding high voltage on cells for an extended time causes some degradation. Doing so briefly would be minimal, especially in your climate-controlled workshop.
If you do NOT top balance your cells, then if SCC charges the pack to target voltage and no cells are so high as to cause BMS to disconnect, some cells will be up the knee toward 3.65V while others are down around 3.3V. So not balancing would accelerate degradation, especially if environment is hot.
Maybe passive balancer will make them similar eventually. I would top balance one time to start. That need to be higher not lower than what SCC is going to do.
