Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 23,285
At a minimum the bulb will eliminate the pre-charge step. If the benchtop power supply is low amperage, might as well leave the bulbs in place while top balancing. In theory if a bad cell shorts, the voltage difference will light the lamp.
"Precharge", I think you mean charge to similar voltage before connecting in parallel. Which probably means something if some cells are near 100 SoC (above knee of curve) but others are below. If all below knee, I would test with the light bulb and see how close voltage comes. Calculate V/0.00025 ohms to see if surge current is a concern.
Some people have completed parallel top balancing, then when using battery found SoC differed between cells. One was low. Going back to charge that one alone to 3.65V fixed the issue. I blamed it on high resistance contact, so during charging that cell lagged.
If you deliberately add resistance in series with cells while charging, I think they will lag, take far longer to drift up to same SoC.
Finally, I think I have it... Are you proposing to connect cells in parallel using bulbs instead of bus bars? If so, I don't see any useful purpose in that.
Even at low current, they have higher resistance than bus bars and will increase the needed Wh to charge the pack.
Not Wh, I don't think, unless charge current is high enough to burn significant watts in the bulb.
But h (hours) definitely.
