Hello,
I have a 100Ah 2p8s pack made of EVE 50Ah cells I recovered from a commercial rack pack. The bus bars appear to be welded or glued to the cells' terminals so no way to reconfigure the cells. I performed a top balance by charging each pair of cells to 3.65V with a bench PS (while they are still connected together obviously since the busbars cannot be removed). Went around the pairs several times to be sure they were all equal at 3.65V.
Problem: after discharging the pack to 24V (measured capacity 90Ah when discharged stopped), all the cells pairs were between 2.87V and 3.02V. After recharging the pack as a whole, the charge is stopped by the BMS with one pair at 3.63V and the lowest at 3.4V.
Is this supposed to happen? I thought that my top balancing would ensure that all the cells would reach their higher voltage simultaneously?
If not, what else could be wrong?
