SolarUKWM
System: 2 x Pytes V5 48V Server Rack Batteries (total 200Ah) PACE BMS connected closed loop with Ecoworthy 5000 All In One.
Is it worth occasionally doing a non-comms-controlled charge to let the batteries "top balance"?
Motivation :-
When monitoring a BMS controlled charge, it charges at constant current (40A set) from start to finish, and immediately terminates the charge at 56.5V/40A = 100% reported SOC. That's a rather sudden stop.
This is not the charge profile I'm used to for Lithium-anything or Lead-Acid batteries: CC up to the voltage limit, then hold at voltage limit (CV) until
current falls to a threshold. Then either stop, or change the voltage set point to a lower "float" voltage.
When charging without comms connected, the same constant current to 100% SOC occurs. But then, it spent a further half an hour held at 56.7V (the CV part!), with the current slowly falling 40A -> 2A, both batteries and Ecoworthy showing as "charging".
At which point the charge stopped, as it went below my 2Amp limit, but could have continued further.
This is what I would consider "normal charging" profile. CC, CV, terminate.
I think: This CV final phase/absorption/whatever you call it is needed to let the cells top-balance off and for the BMS to discover the *real* 100% charge point, and reset the coulomb counter? Otherwise, when does top-balancing get to happen?
But is it something that needs to be done often?
There doesn't seem to be any controls for changing charging behaviour to hold beyond 100% SOC -- other than cutting comms with the BMS.
Thoughts welcome!
Mike.
Motivation :-
Thoughts welcome!
Mike.
