schroederjd
- Nov 12, 2020
- 175
Hi Everyone,
While waiting for my cells to come in (16 x 272Ah Lishen) from China, I've been working on a top balancing setup. Objectives were 1) don't damage the cells, 2) get the job done in < 2 wks, 3) don't spend more than $100. After reading several threads related to top balancing with Mean Well power supplies, I decided to go in that direction. I purchased a HRPG-300-3.3 from TRC Electronics. Price was $98 after shipping. I went with the HRPG over the HRP because it has the remote on/off and remote voltage sensing features.
The more interesting part of this is how to meet objective 1 (don't damage the cells) without constantly checking the voltage. That's where the microcontroller comes in. I used a Node32s (ESP-32), as I had one on hand, and it has multiple analog inputs (ESP8266 only has one). I used Arduino IDE for the programming along with the Blynk iOS app for remote monitoring. Wiring diagram of the system is shown below. I'm using an open-loop hall-effect current transducer (LEM DHAB S/133) that came with my TinyBMS for current monitoring. I've coded in a non-reversible remote shut-off for when the current reaches a pre-defined set point. This set up allows me to remote monitor the charging from anywhere, and kills the charging automatically so I don't risk overcharging.
I'll post the code once I have it cleaned up. Probably the most complicated part was trying to get the ESP-32 to provide accurate volatge reading (the ADC has a non-linear response). The Blynk app made the remote monitoring setup super easy.
After a lot of testing and tweaking, the system seems to work great. Voltage and current readings are spot on, and the remote shut-off kicks on reliably. I would really appreciate any feedback (risks, design flaws, ideas for additional functionality, etc.).
Circuit diagram:
Here's the dashboard I've set up in the Blynk app. Nothing too spectacular, but it allows me to see what's going on...from anywhere.
Circuit diagram:
