Vanhandler
- May 10, 2021
- 8
I have 12 Eve 280AH Grade A brand new cells from Amy. The resting voltage of them was around 3.29 and each cell was within about .001 of each other. great.
After realizing I didn't purchase additional bus bars, I could only top balance six of the cells in parallel at a time. no problem.
I compressed the cells using 4 threaded rods and a plastic cutting board - cut in two - as end plates.
I attached my 10A bench power supply after setting the voltage to 3.65 and I was off to the races! I noticed the PS was pushing only around 5A and 16/17 watts which I thought was strange but left it. After about 24 hours, the cells were had only charged up to about 3.31v. This was going to take forever! After reading some of the forums, they suggested using a thicker gauge wire from the PS and using ring terminals. Great. I used 10 awg wire and ring terminals. I set my PS to 3.65 and connected my ring terminals to the paralleled cells. Now my PS went from C.C. to C.V, the voltage was reading around 3.47, amps were at 10.33 and my wattage was 35.84! amazing- it worked! this will take half as long. wrong.
I started documenting the progress and this is where I am at:
48 hours ago my battery cells were reading 3.327 and my PS was at 3.47v/10.33A/35.84W
Now my cells are at 3.367 and my PU reads 3.51v/10.32a/36.22w.
so in 48 hours, my cells have charged .04 volts.
at this rate, it will take me another 14 days to charge to 3.65v.
What am i doing wrong?
thanks in advance.
thanks in advance.
